Post Buff: Light Bench Rash Scratch Remover? http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=56534 |
Author: | Kbore [ Fri Apr 19, 2024 1:53 pm ] |
Post subject: | Post Buff: Light Bench Rash Scratch Remover? |
What are your favored abrasive polishes for removing very light scratches, from handling, on 3-month-old NC lacquer? StewMac's FINE on the buffer will take out the very lightest. SM MEDIUM followed by FINE would probably take them all, out but I don't want to take it to the wheels after everything's assembled - punctuated by several buff throughs already on this build. I have two different very fine metal polishes (Flitz and MaaS) that remove very very fine scratches but would like something a tiny bit more aggressive for this bench rash. I have 3M Finesse glaze for automotive clear coat but don't really want to put it to guitar lacquer, I'm not sure its even abrasive. Meguire's 9 ? |
Author: | Chris Pile [ Fri Apr 19, 2024 2:06 pm ] |
Post subject: | Re: Post Buff: Light Bench Rash Scratch Remover? |
Believe it or not, in a pinch toothpaste works pretty well. |
Author: | SteveSmith [ Fri Apr 19, 2024 2:11 pm ] |
I use Novus fine scratch remover. I’ve also used toothpaste in the past although mostly on hard plastics. |
Author: | bcombs510 [ Fri Apr 19, 2024 2:14 pm ] |
I use the 3M PerfectIt 06068 and the 3M 05990 Hand Glaze for final spit shine. The PerfectIt is great for what you’re saying, fixing without going to the buffer. The other option, if you aren’t covering a lot of area, is a felt block with your same SM compound on it. Sent from my iPhone using Tapatalk Pro |
Author: | Hesh [ Fri Apr 19, 2024 5:50 pm ] |
Mequires has a number of products such as fine scratch remover that work great on guitars too and are available in every town USA, Canada and beyond... maybe... ![]() |
Author: | John Arnold [ Sun Apr 21, 2024 11:45 am ] |
I mostly use 3M Finesse It with a buffing wheel mounted on a variable speed drill. Swirls left from that process can be removed with 3M Hand Glaze. For more aggressive polishing by hand, I use Mother's Mag and Aluminum Polish. This is for all guitar finishes, including nitrocellulose lacquer. Sent from my SM-G950U1 using Tapatalk |
Author: | Pat Foster [ Tue Apr 23, 2024 2:20 pm ] |
Chris Pile wrote: Believe it or not, in a pinch toothpaste works pretty well. The toothpaste I used in a pinch was Arm & Hammer baking soda based. It starts out fairly aggressive and breaks down to a finder abrasive with use. |
Author: | Kbore [ Tue Apr 23, 2024 3:00 pm ] |
I think building guitars then repairing the f-ups is how refinishers are born. I'm going to finish this build process then string it up before I start the "re-finishing" process. I've somehow become the bull-in-a-china-shop. I think as my wood/ tool/ WIP inventory grows, my shop working space is consumed by it. Thanks for all the suggestions on rash polish! |
